Ansys Learning Forum Forums Discuss Simulation Preprocessing I need help with double pipe heat exchanger Reply To: I need help with double pipe heat exchanger
Under Surface creation you can add points to the domain, and then Report Definitions to those.
In an unconverged solution the problem can be mesh or setup related or that there is something going on in the flow field. The monitors and images taken every few iterations can help identify the issue.
