Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical HEAT tessellating › Reply To: Lumerical HEAT tessellating
September 29, 2023 at 12:00 pm
Dear Dr. Sun,
Thanks for your helpful and prompt reply. Â Following your suggestion, the simulation can be meshed now, but it is still not converged. Also, the geometry of imported heat source (absorption simulated by FDTD) is changed. For 7 close packed core-shell nanoparticles, the diameter is 5 nm, the thickness of shell is about 2 nm. Could you please help me look about this? Thank you so much.
Best regards,
Jungui
