Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › I need help with double pipe heat exchanger › Reply To: I need help with double pipe heat exchanger
Assuming you have velocity in and pressure out I'd be looking at the mesh and add some point monitors to understand the flow field.
