Ansys Learning Forum Forums Discuss Simulation 3D Design Unable to import spaceclaim model onto workbench Reply To: Unable to import spaceclaim model onto workbench
Sampat Kumar
Hi Daniel,
It appears that the unsupported file is the cause of the issue. Could you use SpaceClaim to open this geometry file? If so, save it to a scdoc file and open it in the WB later. Would you kindly provide further information regarding the file's issue? How and where did you import into the WB?
Sampat
