Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Spark plug location error › Reply To: Spark plug location error
September 29, 2023 at 9:54 am
Ren
The previous idea is to check if there are three separagte regions: intake port, cylinder chamber, exhaust port. In EnSight, you can verify it by displaying only the "Symmetry" part and color it by Region ID.
In addition, you can also visually check the mesh to see if there are any gaps between the valves and the valve seats.
