Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Lumerical HEAT tessellating › Reply To: Lumerical HEAT tessellating
Jungui Zhou
Dear Dr. Sun,
Thanks so much for your prompt reply. As I followed you suggestion, the simulation can mesh now, but it can not converge. And also when I import the Heat source (absorption simulated by FDTD), the geometry is changed a little bit. For seven close packed core-shell nanoparticles, the diameter of core is 5nm, thickness of shell is 2nm. Please help me look about this.
Thank you so much.
Best regards,
Jungui
