Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Interupting client does not work!? › Reply To: Interupting client does not work!?
September 29, 2023 at 9:12 am
Stop usually works, and CTRL+C also stops the solver. You may need to hit CTRL+C a couple of times if you're running transient.
Some operations, DPM tracks and mesh processes don't have an interrupt as doing so could corrupt the update. These processes can take a few minutes, longer if you accidentally set something incorrectly or your change/update is large relative to the compute hardware.
