Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
September 28, 2023 at 3:44 pm
Staff are limited to what's in documentation, so we're a little stuck until the tutorial is made public. I don't have a time frame for that. Check the theory guide as the maths may well be explained in detail.Â
If a static model is failing check what the initial condition is and whether that's physically sensible.Â
