Ansys Learning Forum Forums Installation and Licensing Ansys Products Corrosion in Ansys Corrosion rate Reply To: Corrosion in Ansys Corrosion rate
Shamkhal Mammadov
Do you have any idea when the tutorial will be posted? or at least whom I can contact to clarify this? the picture I posted above your comment is the total accumulated rate, it sums up all corrosion for a simulation period, and there is no time in units.
I want to try a constant case of corrosion, where Pressure and volume are static, but my simulation blows up. when I set inlet-velocity to 0, or i set inlet pressure and outlet pressures to be the same. Any suggestions regarding this?
