Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
September 28, 2023 at 3:15 pm
Where's the time value in the rate? Otherwise, yes, you will probably need the pipe material density to then covert to mm. This assumes the set up is similar to the erosion models. Once there are tutorials it'll be clearer.Â
