Ansys Learning Forum Forums Discuss Simulation Fluids DPM particle data mapping Reply To: DPM particle data mapping
The particle positions are updated with each particle step, so if you stop the calculation you can see the current data. The data averaging might also be useful.
Be VERY careful with the contour plots with DPM. Read the exact definitions before drawing any conclusions.
