Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Calculating Cycle › Reply To: Calculating Cycle
Are the data in the acceleration table multipliers on the applied acceleration in the FE model? If so, why can’t you use a Time Series Load Mapper in Ansys nCode DesignLife? DesignLife time series load mapping uses one set of FE results and scale factors from a time history file to create time varying stress. If you can convert your time base acceleration data to a PSD spectrum, you can run a DesignLife vibration fatigue analysis using that spectrum, but I do not see why it is necessary (or preferred).
Is the moment load constant or does it vary with time? If it is a constant load, then the stress it produces does not directly contribute to the alternating stress. It acts a mean stress.  The DesignLife time series load mapper has an option to specify a “static” result set. The stresses from the static result set will not vary over time, but they will be used in any mean stress calculations.
