Ansys Learning Forum Forums Discuss Simulation Electronics Problem with PML in circular surface in eigenmode HFSS Reply To: Problem with PML in circular surface in eigenmode HFSS
Pablo Martínez Reviriego
Hi, thank you very much for your reply.
I am trying to simulate a pillbox cavity loaded to a circular waveguide. When I split the full geometry in 1/4, the PML setup Wizard works fine for the port.
 However, if I try with the full geometry, the program collapses.
