Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Problem with PML in circular surface in eigenmode HFSS › Reply To: Problem with PML in circular surface in eigenmode HFSS
September 28, 2023 at 12:26 pm
Hi Pablo,
Thank you for reaching out to the Ansys learning forum.
As the circular waveguide is generally a closed structure, I am wondering why would you need a PML boundary setup. Also, you have mentioned the solution type is Eigenmode. I am assuming the model will be fully covered with the conductor.
Please share the screenshots of your model to help us serve you better.
Best regards,
Praneeth.
