Ansys Learning Forum › Forums › Kampus Merdeka Belajar › Homework – Flow Through 90-Degree Bend Pipe › Reply To: Homework – Flow Through 90-Degree Bend Pipe
Raihan Lutfianto
From what I understand, it is possible numerically. It is still considered close to zero. However, I recommend you to recheck:
- Inlet boundary condition
- Outlet boundary condition
- Solution methods setting
- Residual setting
- Mass balance report definition
- Any reversed flow inside your model
In my case, the solution is also negative. Again, if the overall physics does makes sense, then you do not have to worry about it.
