Ansys Learning Forum › Forums › Discuss Simulation › Optics › Optical Fiber sensor › Reply To: Optical Fiber sensor
Karthik Buddala
Hii, Thank You for your reply. In this below image, You can see two optical fibers, Actually total internal reflection is not happening in these fibers. If i will be provided with sample properties to make it work as a optical fiber it would be helpful. I'm using radiance sensor. and Direct simulation.
