Ansys Learning Forum Forums Discuss Simulation Fluids DPM particle data mapping Reply To: DPM particle data mapping
To an extent yes. Are you looking at steady flow and transient particles or transient flow and particles? Have a look in the contour plots for what's available, and check the definitions in the Field Function list as not all are obvious.
You may also want to read up on Custom Field Functions and Expressions. If you're exporting data I'd favour the former as I can't remember quite where we're at with using expressions for that.
