Niki Papachristou
Hi Meier,
Thank you for reaching out to us. Can you please provide more information on why you chose those two cases for your simulation? It is possible for your work to use a delta source for IQE similar to the CMOS example, and if you need an iteration of response (actual output for a given optical input) you can run optical simulation and import the generation data instead.
Kind Regards,
Niki
