Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Assign intensity to a particular cell in mesh › Reply To: Assign intensity to a particular cell in mesh
September 27, 2023 at 9:20 am
Yes, but you can assign a source term directly without needing a UDF or expression. For energy absorbion by the media you want DO or Monte Carlo radiation models.Â
If you just want to add energy into those cells (heat source) I'd split them out (register and separate option) and then use a fixed source term.Â
