Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Assign intensity to a particular cell in mesh › Reply To: Assign intensity to a particular cell in mesh
Canh Doan
Hi Rob, Do you mean the DEFINE_SOURCE term is UDF code?
As the UDF manual, it is possible except for the discrete ordinates radiation model. However, as far as I know, the radiation heat transfer and the interaction between laser radiation and gas should use the DO model.
