Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Optimetrics failed when link demagnetized PM field source › Reply To: Optimetrics failed when link demagnetized PM field source
HDLI
Hello Qiang Wei,
       In 2nd model, do you do following steps? Linking is not in analysis ->setup.
       1). Select PM from the history tree
       2). Menu item Maxwell 3D/2D → Excitations → Assign → Permanent Magnet Field…
       3). Check the radio button Demagnetization
       4). Click on Setup Link…
       5). Setup General, Variable Mapping, and Object Mapping tabs
       Please go to ALH, demagnetization, two step approach
HDLI
