Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
OK, looks like wall material density has no effect on the corrosion rate. So, kg/m2/s is likely as suspected and you need facet area and wall material density in a function to switch to mm/s.
