Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Subtracting an empty wall from a solid object in HFSS?? › Reply To: Subtracting an empty wall from a solid object in HFSS??
Navya Chode
Hi imtiaz,
I did not understand why you have drawn the empty rectangular wall(Green ) that way if you want to get rid of the centre portion. You can create a sold-empty block that covers the entire middle portion and subtract.
But if you want to do it in the same way you did, you can draw another cube that fits into the middle portion of the design and then subtract it from the (red) cube/wall. While doing that do not select the clone tool part before operation.
Navya
