Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Maximum Eqv. Stress Spot Differences between Discovery and Mechanical › Reply To: Maximum Eqv. Stress Spot Differences between Discovery and Mechanical
Atharv Joshi
Hi Jugyeong,
Ansys Discovery Explore mode requires a minimum of 4gb graphics card and we generally recommend having 8gb dedicated graphics with updated graphics drivers. Ansys Discovery Hardware Requirements (2023 R2) - Ansys Knowledge
Explore stage uses GPU memory for discretization and maybe with 4gb card isn't capturing the geometry accurately. You can check the element size from Simulation Tab >> Fidelity >> Size Preview.
Let me check the results at my end and will let you know.
Thanks and Regards
Atharv
