Ansys Learning Forum Forums Discuss Simulation General Mechanical Rolling joint model check Reply To: Rolling joint model check
peteroznewman
Hello Paolo,
Static structural is the best analysis to use if the velocity is small so that inertia forces are small. When the inertia forces become significant, then you will need to use Transient Structural.
Cable280 elements are better elements to use for this application.
I don't know what you mean by the third bullet. Please explain each in detail.
