Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Upgrading PC to run SBR+ simulation on HFSS › Reply To: Upgrading PC to run SBR+ simulation on HFSS
Hi Vu Vuong,
Setting up an appropriate workstation for your HFSS simulation may be a complicated task. Here is some more insight which will help you decide,
For the meshing stage of your simulation you should consider picking a higher clock speed in your CPU.
For the matrix solve calculations you should aim for the greatest amount of cores. This will significantly reduce your simulation time.
Last, since you refered to SBR+ simulation, I would like to mention that for SBR+ simulations GPU acceleration is available for complex model. So this may be another point for you to consider. You can find some more information on that in the following link,
Ansys Electronics 2023 R2 - GPU Acceleration
