Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
Don't you need the fluid region to attach the reactions too? The fluid side species mixture may alter the corrosion rate. Note, I've not tried the model yet: I am very familiar with the erosion model and it's initial UDF implementation.
