Ansys Learning Forum Forums Discuss Simulation Fluids Stichting boundary layers together Reply To: Stichting boundary layers together
As long as the cell size is similar on both sides of the interface you shouldn't need inflation. I'd generally use poly and that should also improve the mesh between the interface & casing wall.
