Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › WB LS Dyna PreStress Bird Strike › Reply To: WB LS Dyna PreStress Bird Strike
Ram Gopisetti
Hi Mehmet,
you can try to use the dynamic relaxation type Explicit after Ansys solution by connecting the prestress solution to the model of the lsdyna.
You can use assembly workflow and introduce the SPH bird in the second part of the analysis and define as SPH.
cheers, ram
