Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
September 25, 2023 at 3:22 pm
this is CO2 corrosion. Not an Errosion case.
I agree with your assumption, this is a fluid domain. I selected a fluid wall to be a boundary for combined electrochemical reactions.
I have been trying to get help from Ansys, but no one knows.
Will something change if I create a pipe instead of a fluid domain, and setup a corrosion reaction to happen on the pipe's internal wall?
