Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Corrosion in Ansys Corrosion rate › Reply To: Corrosion in Ansys Corrosion rate
Assuming you don't need to set the wall material in the bc panel to be the material in the reaction I suspect the kg/m2/s is based on the reaction mechanism. That's likely the facet (cell) area and you then need the wall material density that you'd like to corrode. That would be consistent with the erosion models.
