Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Warum schwingt die Feder Rigid Dynamics Why does the force make the spring swing › Reply To: Warum schwingt die Feder Rigid Dynamics Why does the force make the spring swing
September 25, 2023 at 2:45 pm
What you say might be true if you applied the force in an initial load step with time-integration turned off. Step applying a load in a transient will produce a dynamic displacement equal to 2X the static displacement and the solution will oscillate between 0 and 2X.
