Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Extracting the normal unit vectors of elements using Command (APDL) and use of the NLHPRE variable › Reply To: Extracting the normal unit vectors of elements using Command (APDL) and use of the NLHPRE variable
jkaempfer
Same here, I would also be intersed to be able to extract the normal vectors of shell elements in global COS to be able to setup a script that can apply pressure in the correct direciton regardless of the normal direction defined in the geometry file. Any ideas?
