Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Correct beam connection to simulate screw › Reply To: Correct beam connection to simulate screw
camilla.gironi4
Thank you for your suggestion.
In the case I use the first setup (the one on the left), how can I model the interaction of the "vertical cylindrical wall" with the top object? Since in reality, there is screw material interacting with the object even if it does not contribute to bolt pretension
Thank you again,
Camilla
