Ansys Learning Forum Forums Discuss Simulation Fluids Where to fined animation definition settings (For changing definition) Reply To: Where to fined animation definition settings (For changing definition)
Vivek Praveen
Hi Walaa,
You can edit previously defined animation settings by going to Outline view tab (tab on the left-hand side, one which shows all the settings as a drop-down menu). There go to Solution --> Calculation Activities --> Solution Animations. Here you will the list of animations you have previously defined. You can edit it here.
Thanks & regards
