Ansys Learning Forum Forums Discuss Simulation Fluids Setup and Solution update problem in ANSYS Fluent Reply To: Setup and Solution update problem in ANSYS Fluent
Fluent is looking for some input data. If you open the Setup cell what happens?  The general workflow now is to use Fluent in standalone mode unless you require Workbench tools such as parametric options.
