Ansys Learning Forum Forums Installation and Licensing Ansys Products SPECTR on the ANTYPE command not available Reply To: SPECTR on the ANTYPE command not available
Mateus Cornelsen
I ran into the same issue doing a very similar analysis. This error is due to the license in use not suporting the random vibration analysis, try switchting to a licensing level premium or enterprise. If you are using a student license it should have run, please check with support then.
You can check more about this on the ANTYPE command section on the Ansys Help
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/ans_cmd/Hlp_C_ANTYPE.html
