Ansys Learning Forum Forums Discuss Simulation General Mechanical User button – Python commands Reply To: User button – Python commands
ErKo
Hi
You can use the record in the mechanical scripting console, and add the directional deformation , etc., and you will see the commands (e.g., AddDirectionalDeformation(), AddEquivalentStress(), etc.)
On how to het the max/min from these results, one can get that by:
equivalent_stress = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddEquivalentStress()
MaxVMSt=equivalent_stress.Maximum
Then export MaxVMSt to a csv file. Search the internet how to export there are many posts on that, e.g., :
https://www.programiz.com/python-programming/writing-csv-files
Finally group is a bit hard, but not really needed in order to create the results, extract max/min and export these values.
If needed folders/groups look at the below link for an example that adds these results and puts them into a folder.
https://discuss.ansys.com/discussion/2540/how-can-add-certain-results-and-group-them#latest
All the best
Erik
