Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Via hole creating › Reply To: Via hole creating
GioF
I don't understand your question.
Create Cylinder -> assign Polymer -> Subtract Cylinder from Substrate (enable Clone tool objects before operation) -> add Finite Conductivity for Face part of Cylinder
If you follow the order above you should be fine.
