Ansys Learning Forum Forums Discuss Simulation General Mechanical Hyperelasticity Model Reply To: Hyperelasticity Model
armin.abedini
Hello Giulio,
I have a suggestion for you: As your prescribed load might be too large, try pulling your specimen under a displacement-controlled BCs rather than force-controlled (you can set the maximum displacement to the one associated with the end of your test). This is also better in line with how actual tensile tests are performed in labs.
