Ansys Learning Forum Forums Installation and Licensing Ansys Products How to make discharge curves (voltage vs cell capacity) using the MSMD module? Reply To: How to make discharge curves (voltage vs cell capacity) using the MSMD module?
spatel
You can do this externally:
use report definitions to write out time vs. voltage and time vs. temperature.
And then simply use 3rd party software (e.g. Excel) to convert the time column to Capacity using dishcarge current*time.
