Ansys Learning Forum › Forums › Discuss Simulation › Electronics › HFSS 3D Component Intersection Issues › Reply To: HFSS 3D Component Intersection Issues
September 22, 2023 at 10:56 am
Uros Mavric
are there any comments related to this issue? having the same problem.
inserted a .a3dcomp (encrypted settings). it is a connector which parts go into holes of a PCB. I tried to subtract the component chape from the PCB but the subtract option doesnt work. I also tried to draw a shape along the intruded pieces into the PCB and sutract those. the subtraction works (I get holes into the PCB which fit to the pieces of the connector). However the solver still copmplains about intercepts.
Thank you for your help.
Uros
