Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Calculating the output power from a coil placed closer to a conductor › Reply To: Calculating the output power from a coil placed closer to a conductor
dinushaxdn
Hello Reshmi,
Thank you for your comment. But according to Lenz's law, the induced voltage should form opposing the magnetic field which caused it, right?
