Ansys Learning Forum Forums Discuss Simulation General Mechanical Static Structural 2D line body importing problem. Reply To: Static Structural 2D line body importing problem.
Bilal AkdaÄŸ
Tried it in 3D too. Still did not work. I found the reason. There was no cross section dimensions. So when I attached a cross section dimension to sketch by design modeler, it worked. But I need something faster. A step file to be imported in sketch so I can define a cross section dimensions in the inside of ansys.
