Ansys Learning Forum Forums Discuss Simulation General Mechanical Error message in autodyn Reply To: Error message in autodyn
ahmed.taher
this is my first time running a model this big, all models I ran before were having maximum of 50000 cycles. So, I don't know in fact if this is normal or not
The reason I am making this model is that, I am trying to apply an axial load to calculate residual stress after a blast stage, the problem is the "stain rate" effect, I need to apply the axial load gradually. in autodyn, the time scale is too small (ms) in which axial load won't tell the true value of stress if it was loaded gradually. So i ran a model this big but it shows the error. the thing is, if I opened a pre saved cycles from the same model, it now shows the error message
So, What can I do? Is there a way to solve this issue? If not, then is there a way to avoid the strain rate effect while applying the axial load?
Thanks,
