Ansys Learning Forum Forums Installation and Licensing Ansys Products Defining Young’s Modulus based on x-Position Reply To: Defining Young’s Modulus based on x-Position
Sampat Kumar
Hi Christopher,
You can check the attached help documents that will help you add the field variable in the Engineering data.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_eda/eda_field_variables.html?q=field%20variable
Sampat
