Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Hole › Reply To: Hole
September 20, 2023 at 12:44 pm
Hello Roberto,
Did you create these holes from within SpaceClaim Standard hole option? Then in the Standard hole you have option to measure depth to the tip and add create a hole from top to the tip of the drill point. Please check the image below for your reference. Â
If the hole is not created in SpaceClaim, then you might want to have a point at a tip and then you can measure it from the top since it would generally measure the hole depth without the drill points.Â
Let me know if this helps.Â
DevendraÂ
