Ansys Learning Forum Forums Discuss Simulation Fluids Residuals not converging (2D supesonic inlet) Reply To: Residuals not converging (2D supesonic inlet)
Essence
Which turbulence model did you use? What are the controls (URFs) you set? Reduce the URFs and once stable residuals reached, turn them to default. Use FMG initialization. Also for higher order terms of discretization, please use High Order Term Relaxation (HOTR) for stable residuals. Use Psuedo time step.
