Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Post processing output of ETABLE – Bending, membrane and peak stresses › Reply To: Post processing output of ETABLE – Bending, membrane and peak stresses
Sebastien ARRIVET
Thanks for your answer ! I just tried the PLETAB command following your input, turns out the output sm11 isn’t stored. I though OUTRES,ALL,ALL would cover it all, but looks like it’s not. I’ll try to investigate that. The element guide said it was automatic in the .rst file (there is a Y in the R colonne) so I though the outres would be enough
