Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › ICFD water suface not initially flat › Reply To: ICFD water suface not initially flat
Caleb Wood
I am trying to replicate results from the following paper in a 3D domain: https://doi.org/10.1016/j.apor.2011.08.002
The reason for replication is to serve as a proof of concept for my future problem, which is modelling a portion of a real-world wharf and subjecting it to wave loadings. The wharf is likely to be modelled as elastic, so the method you mentioned would not work for my full scale problem. It might, however, work to verify the method. I will look into it and come back when I have results.
Thank you for all the help,
Caleb.
